Hi all,
I know the alternator swap has been talked about and documented a lot here and on other forums, but I'm having a hard time finding specific info for:
I have a vintage/historic 240z which I've rewired, completely tore out the old wiring harnesses. I'd like to put in a one-wire alternator, using the same bracket. When I called Motorsport Auto about the 60-Amp Alternator Upgrade Kit, 70-73 240Z
http://www.thezstore.com/page/TZS/PROD/spring03a/12-4068
They said that was for the standard harness, not a one-wire set up.
So, does anyone know if I can use that as a one-wire set up. Or, is there a Bosch/GM/whatever one-wire alternator I can get that will bolt right in using the current brackets? thanks
Bill Oakes
