Will this work?
HybridS30
It's a solid rod, the support should be there with just two. Can't tell from the picture on what you did but the only problem I can see is the linkage on the carb obviously can't connect with the shaft since it's pushed back.
Just get some pliers or vice grips and unscrew that one, replace it with another. Don't know if it's metric or not.
