Noob question- L20 gearbox
Dave-ve
Hi guys, I recently purchased an automatic 81 280zx but the gears are not shifting and I want to do a manual conversion. Problem is that there are very few manual transmissions available where I live (Trinidad WI). The L18 and L20 gearboxes are easier to obtain and I've read almost all the threads related to the L series gearboxes but I still have some questions.
Will the L18/20 box work on the l28 engine?
Can the bell housing off the L18/20 be used on a CA/SR/RB swap?
Thanks, Dave.
It will bolt up to a L28 but I don't think an SR/CA/RB.
If you are spending the money, you could get a KA tranny which is stronger if you machine the bell housing to fit the larger bearing.
I'm working on a Datsun truck and from what I have read, concerning their 5 speeds, I think they have a short and a long case 5 speed. This may cause a problem as far as drive shafts are concerned so just double check the length.
