RebekahsZ Posted May 28, 2011 Share Posted May 28, 2011 I've seen two types of RT mount on the forums, single bolt and dual bolt. The one I bought is single bolt. How do I put some torque on the bolt without the whole thing twisting? What torque setting should I go for on that single bolt going into the poly mount? Torque setting for bolts into the floor pan? I'm thinking about drilling a second hole and running 2 bolts into the poly mount just to stop the twisting while tightening, but that seems like a lot of work. Any ideas? Quote Link to comment Share on other sites More sharing options...
rejracer Posted May 30, 2011 Share Posted May 30, 2011 I tightened mine while the diff was installed. I just used an open ended wrench between the body and the RT mount. With the poly mount attached to the diff, there was no problem with it twisting. Yes there is room once installed. As far as torque, I just snugged it up real well. Quote Link to comment Share on other sites More sharing options...
