Need to id a mystery turbo and wastgate
These were part of a bundle purchase for an abandoned swap. The seller
lost the paperwork, so I have no idea what I have. I was going to put them
in the parts for sale section, mostly due to not wanting to deal with the
external wastegate, but the more I look at the turbo, the more I think I want
to try to use it.
Easlity measured dimensions-
Compressor inlet - 4"
Compressor outlet - 2.5"
Exhaust 2.5" V-Band
The wastegate is a four bolt design, with no obvious manufacturer name.
Even if I keep the turbo, the wastegate will be put up for sale, provided I can figure
out what it might be worth.
Please resize images to 1024 x 768 MAX
Edited by RB26powered74zcar
Image size violation
The compressor housing looks like it's a TO4B or E format. Is the turbine inlet the standard T3 4-bolt rectangular? You can measure the wheels if you take off the housings. That will give you definitive answers. Is there a trim spec cast into the exhaust housing?
Edited by cygnusx1
I thought I grabbed a photo of the exhaust inlet, but I didn't. It is a 4 bolt
retangular, but with a split (sign of a twin scroll?)
The only markings that seemed significant is on the exhaust housing,
either 6060 or 0909, but google did not indicate that they mean anything.
