Aero Z Posted June 13, 2011 Share Posted June 13, 2011 Looking for a set of arizona zcar heavy duty springs. I would buy straight from ArizonaZcar but he says he's out of the rears for 'a while'. I will trade my new Tokico springs (came with Illumina kit). They have less than 500 miles on them. I just don't like the ride height. (even worse with the LS1 swap in it now). Or interested in a set of any nearly new stock/euro springs for an April 73 car. Quote Link to comment Share on other sites More sharing options...
Aero Z Posted July 13, 2011 Author Share Posted July 13, 2011 Still looking...still out of stock at AZC. Quote Link to comment Share on other sites More sharing options...
Apex944 Posted July 14, 2011 Share Posted July 14, 2011 AZC told me they won't be making anymore of the heavy duty springs for the 240Z for a long time if ever when I called them about a month ago....had a pretty rude tone over the phone as well I might add. I instead purchased a set of the 280Z tokico springs from beta motorsports and according to their spec's they are the same spring rate's as the AZC springs. Seem to work quite well for me but I've yet to drop the small block ford into the car and see where and how well it sit's... Perhaps the tokico's will work for you? Quote Link to comment Share on other sites More sharing options...
Aero Z Posted July 14, 2011 Author Share Posted July 14, 2011 (edited) Yes I was rudely told the same thing basically. Would the Tokico 280z lowering springs make a 240z sit at the 240z factory ride height? edit: found the answer to that ? in the FAQ. http://forums.hybridz.org/index.php/topic/88025-installing-tokico-280z-hp-springs-in-a-240z/ I might go this route if I need to. AZC told me they won't be making anymore of the heavy duty springs for the 240Z for a long time if ever when I called them about a month ago....had a pretty rude tone over the phone as well I might add. I instead purchased a set of the 280Z tokico springs from beta motorsports and according to their spec's they are the same spring rate's as the AZC springs. Seem to work quite well for me but I've yet to drop the small block ford into the car and see where and how well it sit's... Perhaps the tokico's will work for you? Edited July 14, 2011 by Aero Z Quote Link to comment Share on other sites More sharing options...
zentech Posted July 15, 2011 Share Posted July 15, 2011 Looking for a set of arizona zcar heavy duty springs. I would buy straight from ArizonaZcar but he says he's out of the rears for 'a while'. I will trade my new Tokico springs (came with Illumina kit). They have less than 500 miles on them. I just don't like the ride height. (even worse with the LS1 swap in it now). Or interested in a set of any nearly new stock/euro springs for an April 73 car. I got a set of after market springs fronts about 11" from top to bottom perch the rears 11 and 1/4" with performance rated tension. Let me know if interested. Quote Link to comment Share on other sites More sharing options...
Dat240 Posted August 2, 2011 Share Posted August 2, 2011 Dave @ Arizona Z car is not rude, just efficient... Sorta like the chinese!! I got a coilover kit, camber adjustment and 4 piston willwood brake kits from him and trust me, they are TOP shelf. Will post pics when I can Quote Link to comment Share on other sites More sharing options...
