josh817 Posted June 21, 2011 Share Posted June 21, 2011 (edited) Not a Z but I have a 521 pickup. Bought a pertronix unit only to find it won't work properly in my dual points dizzy. Looking for a regular dizzy now... I don't care if it is missing it's guts (points, condenser, etc), just as long as the shaft play isn't bad and that the vacuum advance works. Thanks guys. I'm on a tight budget so keep it reasonable please. Edited June 21, 2011 by josh817 Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 21, 2011 Share Posted June 21, 2011 Can you return the pertronix kit? There might be some electronic dizzy's for 4 cyl datsuns at a yard local to me... Quote Link to comment Share on other sites More sharing options...
josh817 Posted June 21, 2011 Author Share Posted June 21, 2011 (edited) If I return the kit I get to eat $25 in restocking and shipping fees... bought it off ebay. Compare the cost of what you may offer + $25 to me getting a single points dizzy and using what I have (which was $60). If you can find a single points dizzy then that would be welcomed too... Part numbers that will work are: D412-69 - 3HIT4U1 D413-99 - 3HIT4U1 D4A2-01 - 3HIT4U1 D609 - 3HIT4U1 D6A4 - 3HIT4U1 1977 4-cyl F10, 200SX, B-210, 620 Truck, 710 - Hitachi - 3HIT4U1 1966-67 4-cyl 411 - Hitachi - 3HIT4U1 1966-69 4-cyl 520 Truck, 521 Truck - Hitachi - 3HIT4U1 1968-69 4-cyl 510 - Hitachi - 3HIT4U1 1971-73 4-cyl B-110 - Hitachi - 3HIT4U1 1974-76 4-cyl B-210, 610, 620 Truck, 710 - Hitachi - 3HIT4U1 Obviously for an L16/18/20 type dizzy. I don't know what motor the B110 came with but essentially the dizzy will have to bolt to the L block I have with that oil pump/dizzy drive tang. Basically what I'm saying is no dizzy with a helical gear on the end, only ones with the keyway. After peaking around I'm seeing old single points going for $10-$25 + shipping. If you go to a parts yard, make sure you get it for a decent price so you can still make a little something and I can get a cheap dizzy. Thanks EDIT: I forgot to mention. I am also willing to take the EI dizzy that doesn't have the ignition module box on the side. I have an HEI module on my Z that isn't in use anymore so I can use that and return the pertronix. The "dummy" dizzy should be cheaper than one with a black box. Edited June 21, 2011 by josh817 Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 22, 2011 Share Posted June 22, 2011 It's $30 from the u-pull-it here which I think means I'm out of the running lol. Quote Link to comment Share on other sites More sharing options...
josh817 Posted June 22, 2011 Author Share Posted June 22, 2011 It's $30 from the u-pull-it here which I think means I'm out of the running lol. If it is the right one, I'd say get it... Do you know the year/model? Quote Link to comment Share on other sites More sharing options...
