s30z L28/Z32 trans Swap drive shaft Question
sqweekykneecap
hey all,
quick question about garrett's Z32 tranny install writeup's drive shaft details. If any one has actually used his instructions for the swap, found here http://forums.hybridz.org/index.php/topic/47599-z32-tranny-install-writeup/ i could use your help!
well i went to this drive line shop around me, tried getting a drive shaft made up using the instructions that garrett gave us.
NOW, the question that came up is, the "Length from the flange to output shaft 29 1/16" "
talking 29 1/16" from weld points? or the center of the flange yokes? and "output shaft" is obviously referring to the slip yoke correct?
i IMAGINE because we are talking drive shafts, the "output shaft" is the slip yoke, and the distance is from the center of the yokes, not weld points....BUT i have to make sure.
thanks!!
-zach
