Coolant Temp Sensor connector
zack_280
I need the wiring connector for a coolant temp sensor located in the P90 head between Cylinders 5&6. It should have been on the 280ZX Turbo, not sure if the non-turbo uses the P90 head, but I would assume that it does.
If you've got one and your're willing to part with it. Let me know.
Zack
You should be able to use the quick disconnect type on that sensor, they are also used on the injector connectors. Autozone, Pepboys, and so on should carry them. If they don't carry them and have a junk yard near you. GM vehicles and Volvos have them on there injectors.
