240RR Posted July 7, 2011 Share Posted July 7, 2011 (edited) Figured I would post up my just started project on here. Basically building a full tube chassis similar to the older Trans Am series and GT1. A lot of 1-3/4 square tubing. Flat bottom with rear diffuser. 350z rear suspension. Q45 VLSD diff. 350Z engine and 6 speed. The Q45 axles work as they are the same spline on the hub end as the 350Z so got lucky there. Axles look to be about 1 inch shorter. I think late Supra front suspension. Trying to build it with a lot of donor stuff...lots of creativity and on a budget. Will end up pulling out the fenders and quarters about 4" per side. Also will pull the rear quarters back about 1-1/2" along with the rear wheelwell opening. Here is the chassis jig I built with pallet rack crossbeams....yes it is straight and level...within .1degree and 1mm and the start of the chassis and the shell Edited July 8, 2011 by 240RR Quote Link to comment Share on other sites More sharing options...
240RR Posted July 8, 2011 Author Share Posted July 8, 2011 just realized the photos did not upload....will upload as soon as I figure it out. I host my pics on Webshots and pasted the link from there??? Quote Link to comment Share on other sites More sharing options...
