SENZA PARI Posted July 15, 2011 Share Posted July 15, 2011 I'm having trouble finding any dimensions or specs on the RB26 exhaust flange (or cylinder head for that matter). Would anyone have any information, or be able to point in the right direction? There's got to be someone with a cad drawing or model somewhere. Would anyone be willing to borrow a stock (or any)exhaust manifold for me to measure? I'd would be able to send it back the same day it arrived. I'd even be willing to cut out a stainless flange for your time. Any info or help would be much appreciated! Thanks, Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 15, 2011 Share Posted July 15, 2011 Let me look, I may have a oem exh gasket. I'll let you know shortly... This guy sells them, butt... http://www.davesport.com/cgi-bin/davesport/DFRB26DETTSS.html?id=Dyf6uxhp Quote Link to comment Share on other sites More sharing options...
SENZA PARI Posted July 15, 2011 Author Share Posted July 15, 2011 Thanks, that would be great. I need to get this modeled for you, and others! Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted July 15, 2011 Share Posted July 15, 2011 Let me look, I may have a oem exh gasket. I'll let you know shortly... This guy sells them, butt... http://www.davesport...tml?id=Dyf6uxhp Look at the bright side, if you order more than 12... Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 16, 2011 Share Posted July 16, 2011 All I have is a pair of new Nissan oem exh. gaskets. I'm sure that is what the above vendor copied... I can loan them to you... Quote Link to comment Share on other sites More sharing options...
SENZA PARI Posted July 18, 2011 Author Share Posted July 18, 2011 (edited) Look at the bright side, if you order more than 12... Ha... I noticed that All I have is a pair of new Nissan oem exh. gaskets. I'm sure that is what the above vendor copied... I can loan them to you... I might just take you up on that, however there's two seperate pieces correct? Is the spacing typical of all ports? If so, then it will work great. If not, I'll still need the dimension which seperates them. I'll send you a PM, thanks! Edited July 18, 2011 by SENZA PARI Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted July 18, 2011 Share Posted July 18, 2011 Just set them on top of some graphing paper or something to establish scale and they can be dimensioned based off of the photo. Now where did I put that bootleg copy of vectorworks? Quote Link to comment Share on other sites More sharing options...
