Drive by Wire connector - 05 GTO - LS2
Kbhead
Hello,
Looking for the Drive by Wire(DBW) connector and wiring for 05 GTO. I have the DBW throttle pedal, but I didn't get the connector and wiring harness for it. Have the engine and transmission harness.
Please email, with how much your asking for it.
Thanks,
Edited by Kbhead
The DBW connector is part of the engine wiring harness, I did an '05 GTO swap myself. It's not a separate harness and connector. I don't see how it could be missing, unless it was cut off, and that would be too stupid.
  • 6 months later...
Well I couldn't find a used harness that I was missing, found a wiring kit that someone posted in another discussion, see the link below:
E40 J1 Harness Assembly for 2005-06 GTO ECM
http://www.eficonnection.com/eficonnection/ItemDetails.aspx?ItemId=848
Not sure if anyone has used this "Stand-a-lone Fuse/Relay Module", looks like it might do the trick for your fuel pump, fan, starter and ac.
http://www.currentperformance.com/Accessories/wiring_acc.html
Edited by Kbhead
