Kbhead Posted July 16, 2011 Share Posted July 16, 2011 (edited) Hello, Looking for the Drive by Wire(DBW) connector and wiring for 05 GTO. I have the DBW throttle pedal, but I didn't get the connector and wiring harness for it. Have the engine and transmission harness. Please email, with how much your asking for it. Thanks, Edited July 16, 2011 by Kbhead Quote Link to comment Share on other sites More sharing options...
Zzeal Posted July 17, 2011 Share Posted July 17, 2011 The DBW connector is part of the engine wiring harness, I did an '05 GTO swap myself. It's not a separate harness and connector. I don't see how it could be missing, unless it was cut off, and that would be too stupid. Quote Link to comment Share on other sites More sharing options...
Kbhead Posted July 20, 2011 Author Share Posted July 20, 2011 I am looking for the wiring harness that comes out from the EMC(C1)or J1 connector to the Accelerator Pedal Position Sensor. I seem to only have the two harnesses that come out from the ECM(C2,C3). Quote Link to comment Share on other sites More sharing options...
Kbhead Posted January 25, 2012 Author Share Posted January 25, 2012 (edited) Well I couldn't find a used harness that I was missing, found a wiring kit that someone posted in another discussion, see the link below: E40 J1 Harness Assembly for 2005-06 GTO ECM http://www.eficonnection.com/eficonnection/ItemDetails.aspx?ItemId=848 Not sure if anyone has used this "Stand-a-lone Fuse/Relay Module", looks like it might do the trick for your fuel pump, fan, starter and ac. http://www.currentperformance.com/Accessories/wiring_acc.html Edited January 25, 2012 by Kbhead Quote Link to comment Share on other sites More sharing options...
