Easiest way to remove door hinges from body?
Nismo_Gizmo
Do I have to pull the dash to remove these? I am repainting my door jambs, and I don't want to have to mask them off and have the whole area look half assed.
I have already pulled the doors, and from what I can tell, the hinges are threaded from the inside.
No on removing dash.
Grab the FSM. You did look to see where they are mounted right? The bolts are direclty on the other side. Just watch for any shims that may fall off.
I have a book, but its not the fsm, and they documented everything except those hinges for some reason. Looks like ill have to remove the speaker cover moldings then. Thanks for the quick reply.
Yep that's is it and of course the uncomfortable sitting on the knees time!
