ineedboost Posted August 18, 2011 Share Posted August 18, 2011 (edited) Hi guys, I'm thinking about buying the emusa 240sx coilovers for my Z. If I buy them, I will not be using the 8k/6k springs that they come with. According to this thread: http://forums.hybridz.org/index.php/topic/88915-coilovers-emusa-vs-megan/ The springs that the coilovers come with are 8" long. Is there any reason that you couldn't replace them with 10" springs that have a much lower spring rate? I was thinking of going with 200lb/in front and 225lb/in rear. I would assume that since the spring rate is lower you would want to have a longer spring correct? Thanks in advance. Edited August 18, 2011 by ineedboost Quote Link to comment Share on other sites More sharing options...
johnc Posted August 18, 2011 Share Posted August 18, 2011 Probably OK. You need to think about ride height, strut tube length, and bump travel to determine lower spring perch position. Quote Link to comment Share on other sites More sharing options...
