Oem sized gauges for 1jz
ZmattZ
Im forced to start driving my Z to work and have not yet found gauges for my new OEM dash. I need an option that will fit the OEMs tach/speedo and water temp,oil temp, and pressure that will work on the 1jz. having trouble finding what size gauges I would need to but to work on the 1jz and fit the oem dash. Have any of you had success on this? The only thread I found some info on was someone saying they used a 280z tach, but not sure if i could use the water temp/oil gauges.
i mean connection wise. do you run a jz engine? ive read i need to change the water temp to a different thread type.
yes I have a 1jz swap. I have a build thread on this page. You will need to change the thread. I welded a aluminum bung to my water neck.
