RB25DET in 260z
fxmdb
Ok guys im new to the Z world but i have been in professional racing for a while now , i thought i should ask you guys that did the swap already how did you do your wiring , I know i can buy wiring from McKinney but what about cabin wiring ,relays, ignition switch ??? i got the motor mount kit from McKinney (great products) and everything is in only thing left to do is wire it up , well more like im lil stuck :) , i will be using HKS F-Con V-Pro as EMS . Please help !
Thanks guys
http://forums.hybridz.org/index.php/topic/50138-chris-rummels-easy-follow-rb-into-z-wireing-guide/
Take a look around the site, especially the RB forum ( http://forums.hybridz.org/index.php/forum/31-nissan-rb-forum/ ) and use the search function. Everything regarding a RB swap can be found this way.
Good luck with the build.
