280zx motor build
I bought a 2.8 f54 block from a junkyard had it cleaned inspected, de-glazed and crankshaft polished. everything came back good so i ordered std bearings and rings and gaskets from zcarsource.com
I just put the crankshaft in with the bearings/lube and torqued it down to 40 ft/lbs following the FSM.
now to the problem...
i went to spin the crank and i can only turn it by pushing on the counter weights? It should spin fairly easy right?
well i was going through the fsm today and read through installing the crank again and realized i forgot to align every thing by giving the end of the crank a good smack with a mallet. So i loosened all the bolts smacked it and tightened everything back down to 35 ft/lbs and i can now turn it with my hand.
