Danno74Z Posted October 2, 2011 Share Posted October 2, 2011 (edited) Finally putting together my axle assembly! This should be practically bulletproof for my HP needs. Danno74Z FYI Stub Axles Made By: Chequered Flag Racing.net Joseph P. Siam 9833 Deering Ave unit I Chatsworth Ca 91311 818 350 6222 Edited October 2, 2011 by Danno74Z Quote Link to comment Share on other sites More sharing options...
rsicard Posted October 6, 2011 Share Posted October 6, 2011 I used Modern Motorsports for BEEFY stub axles. Worked with them to come up with as bullet proof axles as possible. Eliminated the undercut between the splines and inboard bearing mount on the axle as this may be the weakest spot when much torque is applied. Also went with the Z31 Turbo CV four bolt flange half shafts and Clutch Limited Slip 3.70 differential. Quote Link to comment Share on other sites More sharing options...
