Timing advance curve problems?
ComicArtist
Well, just dropped a stock L28 back in my '78. However, running into some timing problems.
The distributor on the motor I got had some aftermarket sensor inside the dizzy for picking up the signal to send to the ignition module, and was running some crap aftermarket module, so I just swapped out the sensor and wheel under the rotor with an old locked distributor of mine. Just wired it back to the stock ignition module.
However, now when I start it, the idle is fine, but under load until about 2k rpms, it bogs and misses slightly. Like it has no pick up at all, it will barely move. However, once about 2k rpms is reached, it picks up and runs and pulls fine.
I'm guessing my problem is in the advance curve, but I don't know how to set it. Do you use just a regular timing light with the timing marks on the pulley? Any input would be appreciated.
Thank you!
Will it automatically set the advance curve for the whole powerband?
Also, when I replaced the six-pronged wheel and ign. module pickup sensor underneath the rotor, I noticed the sensor was timeable as well. If you loosen one of the screws holding it on, it's adjustable. Could that have something to do with it?
A distributor has a set advance curve, no matter where you time it at idle. You can't change the advance curve without physically modifying its innards.
Therefore, the answer to your question is yes, the advance curve is already set for the entire powerband from the factory. You must set the correct static timing. Take a peek inside the FSM and it will have everything you need to know.
