KA24 Flywheel on L28et
Wangan280
I've got a lightened KA24 flywheel on a tired NA 280Z. It is holding up
well, and the motor is much more responsive. This was an eBay
package deal, and the clutch was not anything special.
What clutch do you have? I just don't know if a KA clutch will work.
I cannot locate my eBay records, but I think I bought a stage1 or stage 2 package kit.
I used everything but the throw-out bearing, which did not fit over the input shaft.
The disk was the same spline, so no issues there.
Since you planning to put it behind a turbo, I'd suggest that you need to have a
pretty stout pressure plate and/or a more aggressive disc.
