palladin Posted December 3, 2011 Share Posted December 3, 2011 They just went out. The combo switch checks out OK. Even if I connect the #10 & 11 wire (page EL-73 of the FSM)at the main harness, I get nothing. The #11 pin on that connector is burned, but the fuses and fusible links check OK. The tail and stop light sensor has been swapped out. I'm thinking that #11 wire goes to a relay or even hidden fuse somewhere and that is the problem. Any thoughts or been down this road? Quote Link to comment Share on other sites More sharing options...
award280 Posted December 6, 2011 Share Posted December 6, 2011 I bet dollars to donuts that the combo switch is fried. I've been through 3 of them. Each time they would go out, no gauge or tail lights. You are pulling all the juice for the headlights through that switch. Add some relays and it will help alleviate the problem. Quote Link to comment Share on other sites More sharing options...
