Mounted LS2 truck coils today
Dan_Austin
I don't have access to a machine shop, so I thought I'd try for cheap and simple.
I'm fairly pleased with the results.
Materials (about $45)
(2) 20" 1/4-28 all-thread
(4) 1/4-28 nuts and washers (4 nylock nuts to be installed after final tweaks)
(4) 4" 3/8 OD .49 wall T6061 aluminum tube
(4) 3.75" 3/8 OD .49 wall T6061 aluminum tube
(4) 3.55" 3/8 OD .49 wall T6061 aluminum tube
(2) 4" x 3/4" x 1/8" mild steel bar
(1) 6" x 3/4" x 1/8" mild steel bar
The coils are spaced apart with the tube using the pattern 4" - 3.75" - 3.55" - 3.75" - 4"
The end brackets were fairly simple, a 90 degree bend 1" from one end, then a
90 degree twist about 1.5" from the other end. I twisted the brackets in opposite
directions and mounted them such that the brackets would pull against each other.
I then drilled 1/4" holes 1/2" from both ends. The short ends had their corners
rounded off using a bench grinder to fit in the valve cover hold down pocket.
(sorry I did not get a good picture of these)
The upper middle bracket was eyeballed, and has loop on one end formed with a
vise and pliers, and a 15 degree or so bend 1" from the other end to provide a slight
lift to the outside aluminum rail.
About 90 minutes worth of puttering to make and adjust the brackets. Once the
coil rails were tightened the whole structure became very stiff, and trying to twist
or flex the setup just moves the whole motor. I still need to trim the all-thread and
replace the standard nuts with some nylock nuts.
Edited by Dan_Austin
  • 5 weeks later...
I was planning to use a microsquirt for the size and ready to go
nature. While asking about the new V3 features I was offered a
chance evaluate and provide feedback on the sequencer.
So next month the rebuilt motor goes in and start the MS journey.
Oh, and I saw a similar bracket using aluminum tube on a BMW
forum, but the bar stock supports I can claim credit for, and the
dimensions.
