T3 Wastegate Actuator
Neveragain55
So I saw all the Garrett T3 turbo wastegate actuators on eBay and I’ve been all over the various turbo rebuild web sites and I haven’t seen anything that resembles or comes close to the stock wastegate actuator that came off of my original turbo set up.
I’ve combed over the posts in here and haven’t seen anything on where one would go to source one.
Do any of you know where I could source an actuator that will bolt right onto the turbo or are there any other aftermarket ones that will work with the original set up?
I've attached pictures of mine for reference.
Thanks in advance gang……..
I know you said you already got everything but I just used the obx bracket and a cheapo threaded rod wastegate both from ebay.
I found the actuator from this web site for $39.00 bucks: http://www00.mailcar.net/catalog/index.php?seller=mpgstore&main_page=product_info&mode=s&schm=1&cLink=c&products_id=380303320381&psemtrk=google&utm_campaign=EcommerceStoreMarketing&utm_source=GoogleBase&utm_medium=GoogleBase&utm_term=GoogleBase
I found the bracket from this web site for $29.00 bucks: http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-WGT-011&Category_Code=WGT
The actuator I found is also the same one on eBay, I attached some pictures.
