Triple DCOE -Manifold needed- Cannon.
cygnusx1
All is not lost. How badly broken is it?
I repaired one where the connector casting between runner 2-3 was broken such that a 1.5 in diameter hole was left in the side of the #2 runner with that broken out plate still attached to the connector casting. It was a "cleanish" break. no little bits or shards.
I fixed it using HTS 2000 welding rods, which I've grown to absolutely love. Totally easy using MAP gas torch. Put up some pics and I'll give you some ideas once I see it.
If I remember tonight I'll take a couple of pics of the repair I did to help you understand how big the problem was and how easy it was to fix.
Jim
Edited by z240
 I bought a brand new one today since UPS is buying.  I will keep the old one and definitely take your advice for the repair.  It's a clean break between 2nd and 3rd runners, bent linkage, and a dented velocity stack.
Edited by cygnusx1
