Guest Anonymous Posted December 11, 2000 Share Posted December 11, 2000 I know nothing about this but...does anyone know if a dry sump oil system is available for the 302? Seems to me it would eliminate the oil pan problem, allow you to place the engine even lower (as long as the harmonic balancer wasn't hanging up on anything), plus allow you to move the oil reservoir rearward, helping weight bias. Quote Link to comment Share on other sites More sharing options...
Guest scca Posted December 12, 2000 Share Posted December 12, 2000 a dry sump is available for any motor..... for a ford your looking around $2000-2500 complete (and thats green not red money ) a good 3 stage pump is close to $800 a 14 quart tank is $300 , oilpan $400, loads of -10, -12 fittings and lines $400 crank nose and pulleys, drysump mount $250 misc. hoses and lines and inline filters etc............. i spent close to $2k to do my race car and got a pump used from a late model stock car. ------------------ Mike mike@fonebooth.com http://www.fonebooth.com/brakes.html raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 12, 2000 Share Posted December 12, 2000 Dr., Look for a mid-80's mustang bi-sump oil pan. Its got a small front sump and a large rear sump that will work. It'll clear the crossmember by about an inch (depending on your mounting scheme) according to a article I read on another web page. I think Milodon makes a circle track pan that is rear sump, but its rather pricey (250.00 or so). Regards, Lone Quote Link to comment Share on other sites More sharing options...
