Guest scca Posted March 21, 2001 Share Posted March 21, 2001 OK,, i'm really close to going 5L.. 91-92 were the best? or i guess more importantly which years do i want to avoid? i want to run a "stock" 5L with stock FI and a 5 speed. the only upgrade i will want to do is install alum heads to lower the weight. Alsil... get your pics up.. i think i'll do the rack setup as you did too... and the mounts like Dan (Fla) did are very nice.. ------------------ Mike mike@fonebooth.com http://www.outlaw-brakes raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
alsil Posted March 21, 2001 Share Posted March 21, 2001 anything after '89, I would say. they didn't change much after that, except for '94-'95, which had a different intake, harness, computer..... Mike, check out my frame mounts for the 5.0 - fits well and makes a ton of room. I'll post some pics of the crossmember modification this weekend - had to replace the camera, it busted. But for the crossmember, I cut the engine perches off, the rack perches off, and welded on an 18" long piece of 1x1 to the front of the crossmember with 2 2.25"x3/4" tube pieces welded to that 15.5" apart, and slid the rack right on- fits perfect, 1" below the crank pulley - use tie rods froma '95 Mustang, and a stock '94-'95 steering shaft, cut and weld to stock shaft. Not too tough, I'll have the pics up this weekend like I said. Motor mount pic: http://zcar.netdojo.com/pics/302motormount.jpg Al ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
alsil Posted March 21, 2001 Share Posted March 21, 2001 Also, you don't have to worry about weight too much, since the stock motor is already about 75lbs lighter than the stock Z motor- lots of aluminum already. That's 90% of the reason I went with the 5.0 motor, it's WAY lighter. For teh steering rack, I left out that you have to cut down the inner tie rods 5 inches per side, and weld them together. ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 21, 2001 Share Posted March 21, 2001 i'm not afraid of welding so thats no biggie............ Mike Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 21, 2001 Share Posted March 21, 2001 is the 5L lighter than the L6 stock??? if so i'll save$ and not go for alum heads.... oh and Al i couldnt load the page with your motor mount! Quote Link to comment Share on other sites More sharing options...
alsil Posted March 21, 2001 Share Posted March 21, 2001 Try it now, I guess the server went down for a while. The total weight of the 5.0 motor and tranny way 403 lbs dry. That's WAY lighter than a 350 (525-560lbs) and a Z motor (about 460), so save your money. Although, the aluminum heads will give you more power, but since weight is not an issue, I would go for either the Sportsman heads, or GT40P heads. They are iron, but they are a better design. Just some thoughts. AL Oh, and I would ditch the stock harness for the EFI conversion. Not stable enough. ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
Ray Posted March 21, 2001 Share Posted March 21, 2001 Depends on what you are going to do. The early motors 87-89 all have forged pistons. They are real popular here in Houston. Alot of the Mustang guys take the stock short block, rering, chang the cam, put good heads on them and spray them. They seem to last and put out alot of HP. If you are looking for good flowing heads the later explorers have GT40x heads but cast pistons.... Look arround 5.0's are everywhere and the stock parts are really cheep. 100 to 300 down here will get you a really good long block... ------------------ Remember it is only a piece of metal. Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 23, 2001 Share Posted March 23, 2001 Al......... can you clarify the "unstable" thing??????? Mike btw- found a 92 5L with T5 K/N filter and headers/ hurst shifter with H pipe for $1200 complete with wiring/computer etc.. seem decent?? 80000 miles. ------------------ Mike mike@fonebooth.com http://www.outlaw-brakes raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
alsil Posted March 23, 2001 Share Posted March 23, 2001 Any wiring harness that bursts into flames from turning on too many things at one time and melts the fuse box qualifies!!! But seriously, the Z wiring harness is weak at best, and with EFI, you have to have a constantm CONSISTANT voltage to the ECU. If not, it will run uneven, will have starting problems, etc... It relies on a constant regulated voltage from the battery. This can be fixed by wiring the battery directly to the power Lead on the ECU, but you also have to splice in the EFI harness to the stock harness. I was going to just skip the whole thing and go for a Painless Harness. Only about $280, and has everything. I will go for that eventually, anyway, probably when I convert to EFI. Unforunately, the Painless 5.0 harness is not available yet (from what Summit Racing tells me), which would be ideal, getting both. Al ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 23, 2001 Share Posted March 23, 2001 there are a few harness out there for 5L already. i dont know off hand but i have heard that Ford Motorsport has one, and i've seen some wiring harness' for installing a FI 5L into a 65 stang.. so somewhere out there already makes it.. the magazine i saw it in was over 3 years ago.. no not new.. Mike Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 23, 2001 Share Posted March 23, 2001 got the motor mount pic.. is it alum or steel? are both sides the same? hmm now which way to go? ------------------ Mike mike@fonebooth.com http://www.outlaw-brakes raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
alsil Posted March 23, 2001 Share Posted March 23, 2001 EFI Harness: The Windsor-Fox one seems to be the best value, since it includes everything. The cost at first seems high (over $600), but after you factor in the fuel pump (over $200), inertia switch, EFI harness, ALL sensors, and instructions. The frame mount is made of .250 steel. A friend of mine made it at his shop for me, I just drew it out and he built it. Took him one day, where it would have taken me about 2 weeks fo trial and error. I can send you a drawing if you like, but I will be making one to post on my site. Pretty much, I bolted it up to the motor, lowered it in place, slid the engine back as far as I could, marked the holes, and drilled. Pretty easy considering how much hair I pulled out trying to figure out the best way to do it. For the tranny, I am using the JTR bracket, but I drilled it out for the 2 bolt tranny mount for the ford. You CANNOT USE THE STOCK FORD TRANNY MOUNT!!! It is WAY too tall, and the tranny will hit the top of the trans tunnel. I found one at the local parts store that will work, that is half the height. I will post the part # on my site when I get to the house (forgot to write it down this morning, meant to). then I bolted it up the same as the JTR manual. I am adjusting the tranny angle today, to set it to the same. So far, I have a pinion angle of 5 degrees, and a TRanny angle of 4 degrees. So I'm going to raise the rear of the diff by taking out the washers on the top. Should give me that extra degree. What year car are you using? The shifter comes up in the stock '72 and up location, so you can't use the early console. Also, if you're eliminating the smog pump and AC, you don't need to use the eliminator brackets, I found the right belt part # to fit the reduced length. Al ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
alsil Posted March 23, 2001 Share Posted March 23, 2001 Oh, and yes, the frame mount is the same for both, except there is a .250" difference in the mount height for the tube the bolt goes through. it's higher in the front for the angle of the motor. AL ------------------ http://zcar.netdojo.com My Upcoming Solo Album Site Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted March 24, 2001 Share Posted March 24, 2001 scca, I agree with Alsil about going with cast iron heads, the weight savings is a non issue in my opinion. If your interested in low cost CNC ported iron heads checkout PowerHeads @ www.powerheads.com/ you can get a complete pair of CNC ported heads for as little as $635! Mark ------------------ " Now where did I set my beer? " Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted March 25, 2001 Share Posted March 25, 2001 I don't agree with the "non-issue". I've picked up both iron and aluminum Ford heads - there'a BIG difference between them! IF you can afford the lighter aluminum ones I'd go for it. Aluminum heads can be repaired, weight less, generally flow pretty well, and can allow you to run a higher compression ratio without fear of knock. What's not to like? Yes, it seems a Ford motor weighs less than the SBC but you're also giving up 50 cubes over a 350 unless you go high dollar and stroke the 302. For that matter - why not look at a 351W? Many of the parts are the same and it's just a little wider. The blocks are stronger too but they don't like to RPM like a 302 - main bearings are bigger and the bearing speed gets too high (shrug). Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 25, 2001 Share Posted March 25, 2001 first the convertible has no roof and will have no roll bar- i have a rollbar that used to be in it but i currently like the "clean" look of no bar. i used to have a 95 stang with underdrive pulleys, 3.55's , bigger headers/exhaust. i think it had a chip too--it was pretty fast for a 3200lb? car it will be PLENTY fast for the convertible! its Bloody hot in the sun with no roof above you so i will eventually have AC as well, and maybe PS.. i tinker with the racecar enough i want the convt to be a turn key - no muss no fuss car, hence staying relatively stock 5L and i want to use cheapo 87 octane gas too! ------------------ Mike mike@fonebooth.com http://www.outlaw-brakes raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 25, 2001 Share Posted March 25, 2001 I weighed my aluminum headed, aluminum flywheeled, 302 with headers prior to install at 389lbs. I weighed the L24 with exhaust and flywheel at 428lbs. The aluminum heads (J302 Motorsport) weigh 45lbs for the pair, which is slightly more than one cast iron head weighs. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 9, 2001 Share Posted May 9, 2001 Hey I know you are set on a 90's motor, just for kicks check on a 85-gt mtr I had one.I split the exhaust ran a set shorty headers tweaked timing/carb& 1 inch spacer.I think It was a roller mtr?Factory-holley-4180/headers/alumtranny t-5/doublesnorkle,aircleaner/serpantinebelt/stock-HP WAS 215 .Doesn't sound like much but whith these tweaks it would run whith any 90's stang .You could also special order 86 mtr whith a carb wich was fuelinjected.You could tweak it nice.My buddy has a 90 mtr in his 65 stang it runs good.Just thought I'd pass it on -later Quote Link to comment Share on other sites More sharing options...
