vega Posted March 10, 2012 Share Posted March 10, 2012 New project getting all started up just got my heads yesterday. Here are some pics to start. http://i938.photobucket.com/albums/ad226/faytmorgan/1-2.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/2-2.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/3-1.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/4-1.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/topofpistoninmotor.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/327bottomend.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/40overpiston.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/rodandpistonwithcap.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/cylinderwallscoring.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/bottomofhead.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/exhaustport.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/intakeport.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/printout.jpg http://i938.photobucket.com/albums/ad226/faytmorgan/topofhead.jpg 327 small journal (less stress on bearings with the small journals) .40 over forged crank 195cc jegs straight plug aluminum heads (will get the air flow chart next week after knowlton thunderheads gets them on the bench) http://knowltonsthunderheads.com/ This is a slow going build will update the more that is done. vega~ Quote Link to comment Share on other sites More sharing options...
rsicard Posted March 10, 2012 Share Posted March 10, 2012 Looks like a Marine engine. Before anything else, have the block checked for cracks and cylinder walls sonic tested for thickness. It's already .040 over on the bore. Even more reason to sonic test. Quote Link to comment Share on other sites More sharing options...
vega Posted March 11, 2012 Author Share Posted March 11, 2012 Looks like a Marine engine. Before anything else, have the block checked for cracks and cylinder walls sonic tested for thickness. It's already .040 over on the bore. Even more reason to sonic test. Knolton's is going to be doing that for me (65$) when I bring the block to him (travis) we are doing it regardless to see if we want to sleeve it or if we can go 60 over (enough material) apparently some of the older blocks had a lot of material even at 40 over according to him. Also good guess it IS a marine engine out of a Owen's flagship yacht . A lot of weird stuff was done to the motor. flat tops diamond cam 40 over etc. I will update with flow numbers some time this week. Quote Link to comment Share on other sites More sharing options...
traeg Posted March 29, 2012 Share Posted March 29, 2012 280z or zx ? Quote Link to comment Share on other sites More sharing options...
vega Posted April 2, 2012 Author Share Posted April 2, 2012 280z Quote Link to comment Share on other sites More sharing options...
Pyro Posted April 15, 2012 Share Posted April 15, 2012 I would say the smaller journals have less drag (less frictional internal losses). But more stress due to the same load over a smaller bearing area. stress=load/area. Quote Link to comment Share on other sites More sharing options...
