Grounding
Hi,
I'm sure at least one of you has solved this problem.
I'm replacing the mechanical coolant temperature and oil pressure gauges with electric units. The problem is that I would like to use Teflon tape to make sure there are no leaks. Unfortunately, (and obviously) this interferes with the natural grounding of the sensor unit.
What have you done to get a good ground?
Thanks,
Jim
