Wangan280 Posted April 7, 2012 Share Posted April 7, 2012 Hey guys, we're really close but for some reason can't get the spark at the right time. We have fuel and injector pulsing, and the LED light on the ECU is on except while cranking (I think it's supposed to blink while cranking?) We're not far off and we need some help. I'm not sure what this is. WE have voltage to the coil and everything, just no spark. Help. Thanks, Jordan Quote Link to comment Share on other sites More sharing options...
78zstyle Posted April 7, 2012 Share Posted April 7, 2012 Coil properly grounded? Could it be as simple as a bad coil? Is this a coil from a turbo or n/a? Quote Link to comment Share on other sites More sharing options...
monster reem Posted April 7, 2012 Share Posted April 7, 2012 i am getting the same issue ughhh some help would be great Quote Link to comment Share on other sites More sharing options...
Wangan280 Posted April 7, 2012 Author Share Posted April 7, 2012 Coil properly grounded? Could it be as simple as a bad coil? Is this a coil from a turbo or n/a? From what I can tell, yes it's properly grounded, and my coil is from a turbo. He have several coils and they all check out fine (We have a blaster II also) If I had to guess it would be a ground whether it be to the ECU or the coil. This is driving me nuts. Quote Link to comment Share on other sites More sharing options...
78zstyle Posted April 7, 2012 Share Posted April 7, 2012 From what I can tell, yes it's properly grounded, and my coil is from a turbo. He have several coils and they all check out fine (We have a blaster II also) If I had to guess it would be a ground whether it be to the ECU or the coil. This is driving me nuts. Are you also using the coil igniter? Quote Link to comment Share on other sites More sharing options...
Wangan280 Posted April 8, 2012 Author Share Posted April 8, 2012 Are you also using the coil igniter? Yep, voltage seems correct for everything too, we were running through this diagnostic manual and everything pertaining to ignition is checking out fine. We have no idea what it is. Quote Link to comment Share on other sites More sharing options...
