260z cannot find idle below 3k rpm
I have lurked on this forum for awhile now, but haven't been able to find a solution to this problem...
I have a 3/74 260z and I decided to get the motor in it running, (l28 n/a)
I installed a set of weber 32/36 dgv carbs (not new) and got the motor to fire and run. However I cannot seem to get it to idle below the 2.5-3k rpm range, I can get a steady idle at around 3k rpm with the choke slightly on. If I take the choke off entirely the motor climbs to 3k and then slows to around 1k and then starts to "gasp" or shudder and then climbs itself back up to 3k. It repeats this process at a steady pace climbing and falling to rise again. I played with the idle speed and idle fuel mixture screws all day today thinking that this must be the problem, but there was almost no change to the engine response. I did get it to idle at around 1.5k for 30 seconds before it died (this was also achieved using choke manipulation with idle screw adjustment).
I'm not really certain what may be causing this issue? Electrical? Vacuum? Everything seems to be hooked up and operational. Am I missing something? Has something electrical gone bad? I need a little help seeing as I am new to L series motors.
If there's a thread on here covering this specific problem please direct me to it, I tried to find it but maybe the search function failed me. Otherwise any insight or tips would be really appreciated!
Edited by ApexGoblin
Sounds like vacuum to me, masked with choke. Could also be carb balance, as increased engine speed masks that too. Shouldn't be electrical. May just want to hunt for a used set of SUs and be done with it-they have really dropped in price since most of the super motivated speed guys are going hybrid. Nice ones now are selling for what crappy ones used to sell for.
Yeah sounds like vacuum to me too. Check all your vacuum lines for loose connections or cracked hoses, and check the tightness of even your manifold bolts you may have just forgotten to tighten one of them. Ive done that one or twice on my car, thats for sure.. haha. A little air makes a huge difference. The fluctuation leads me to think vacuum. Otherwise I'd say adjust the butterfly's and linkage on your carbs.
Cheers and enjoy the car
Edited by OldAndyAndTheSea
Picture of basic install
Distributor area
Vacuum tank? Haven't touched this besides checking connections/
Cap
And the only things not hooked up are one tube from the smog pump, and whatever goes to that gold plenum (I have no idea where that connects but no matter what I connect to it it doesn't seem to change symptoms)
Hope this helps, of there are any other specific pictures need please let me know.
Thanks for the help!
I have been running Webber carbs for about 20 years, and they are a good carberators. With that said, Apex, that "gold plenum" hooks up to the air cleaner, not the problem. But I would also say you have a vacumm leak,and I also saw that you are missing a NUT that is supposed to hold down the carb. It is on the front carb in the last picture you posted. That could also be part of your vacumm leak problem. Hope this helps.
