pictures of engine mounts
Guest jens
I have found these pictures http://zcar.netdojo.com/pics/motormountdrawing.jpg
and http://zcar.netdojo.com/pics/302motormount.jpg
But i need a little more informantion about the location of the tube. Im not sure but i think he means that it got to be angled a little bit to get the desired engine angle. The side wiew drawing is mishguiding in my opinion help?. That type of rubbermount should be used on the block.
those are alsils mounts.
he uses a 69 mustang engine mount, they use a bolt thru.
i use a early 66 mustang mount - its a stud type.
NOTE.. the type of mount you copy will affect the type of exhaust you can use.
Al has a ford rack (power) and used 2 different brands of headers. so look into this all before you start.
i used flowtech coated headers and i think Dan used dynotech.
Dan has very nice mounts, but i think als are the easiest to copy. mine are similar in difficulty to Dans.
  • 7 months later...
