Guest Anonymous Posted May 11, 2002 Share Posted May 11, 2002 I've been working on a Ford 302 Z upgrade project for some time now and need some advice. 2 Questions? 1: I've taken the old Z wire harness out of my 73 and started to put in a Painless wire harness system. But it's taking more time than I like. Would I make my life easier just to keep the stock harness? 2: If I put in the stock harness does anyone have any notes on wiring up a Ford 302 to a 240Z harness? -Magic Quote Link to comment Share on other sites More sharing options...
blueovalz Posted May 11, 2002 Share Posted May 11, 2002 I'm not using the OEM Z wiring, but only because it's been major gutted, and only the wire that is absolutely needed was added back in. Regardless, if this is a carbed engine, the job should be extremely easy. Basically, a switched 12+ for the ignition, a starter 12+ source for the solenoid is the basics. Then a tach, and other instrumentation wiring can be added. These basic wires can be easily found using a wiring diagram, or if you know what wires were used for these same functions on the OEM engine, then verify their useability for the new application. Quote Link to comment Share on other sites More sharing options...
