Z31 master cylinder prop valve
I have a 1" Z31 Brake master cylinder, that I would like to use on S30, I had it on there once, but didn't work as I had wanted it to, so I am using the original 7/8" master currently.
What I would like to do is bypass the proportioning valve that is built into the master cylinder. I have an external adjustable proportioning valve that I want to use instead.
When I removed the glued on cap to try and remove the prop valve, I was greeted with what looks like a nut that has two holes, so no standard tools here. I tried making a tool out of some metal doweling a 6.5 diesel pushrod, but the doweling is too soft and just bends. A friend of mine and I tried using some punches, clamped together, and twisting them did not release this plug. Is it a left handed thread? Any other ideas for a tool to remove this plug?
