SBC intake renewal
Run a clean-out tap into the cylinder head intake manifold holes to make certain they are clean. Then lube the intake manifold bolts with ant-seize and torque them from the center to the outside. They will be much easier to remove after applying the anti-seize. This process should be used extensively on the engine.
