Guest Anonymous Posted July 26, 2002 Share Posted July 26, 2002 I found a good deal on an 88 5.0 from a t-bird with a 5spd from an 89 GT. I was wondering is there any difference in the physical shape of the 2 engines such as oil pan sump,etc? Also are any of you Ford guys producing motor mounts for the ford conversion yet? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 14, 2002 Share Posted September 14, 2002 None that I can think of! I know the 5.0 that came in the Bronco had a diffrent oil pan setup. -Magic Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted September 14, 2002 Share Posted September 14, 2002 I don't know if I would worry about the oil pans of a ford as a 302 can fit behind the front crossmember. My 6Qt front sump pan is sitting just a little under the xmember and behind. That is as low as I could go and still clear the steering rack with the balancer. I think SCCA (Mike) is going to make one of Asil's (sp?) crossmembers. I think there is a link to some plans if you do a "search" on ford crossmembers. Don Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 15, 2002 Share Posted September 15, 2002 The Fox-body Mustang and T-bird 5.0L motors both use the "double sump" oil pan. Actually, the "front" sump is only there for oil pump clearance. Quote Link to comment Share on other sites More sharing options...
