GOTHALOSISM Posted June 15, 2012 Share Posted June 15, 2012 Ok heres the story, LT1 swap with the CS144 1 wire alt. It worked great untill the battery post inside the alt decided to come loose (they did not locktight the nut). I pulled it apart and reattached the nut and applied lock tight. I then installed new brushes just to be safe. Since then I have burned out 3 regulators. I just got a new one installed yesterday from a alt repair store. I hooked up the 1 exciter wire (yellow from the datsun harness), and a wire that goes directly to the battery. As soon as I turned the key I now have no charging yet again. Does this make any sense? Can I install an external regulator? Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted June 15, 2012 Share Posted June 15, 2012 Maybe the engine block and the car body arent grounded correctly.I have an odessey battery mounted in the back of my car.I ran both 0 size welding cable to the starter=gound and +.the battery should be grounded directly to the engine block.check the voltage on the wire from the key that excites the alternator.Running a ground from the battery to the body -then from the body to the engine is asking for trouble Quote Link to comment Share on other sites More sharing options...
