evildky Posted October 26, 2002 Share Posted October 26, 2002 ok the jtr manual cover all the info on the chevy what about the ford, more specifically the speedo and ther gages ? how do you make them work ? Quote Link to comment Share on other sites More sharing options...
evildky Posted October 28, 2002 Author Share Posted October 28, 2002 aw!?, c'mon guys ! there have to be people here with ford engines and working guages, how did you do it, how is it different ? speek up peeps ! Quote Link to comment Share on other sites More sharing options...
Kimi Posted October 28, 2002 Share Posted October 28, 2002 I think that the guys here have talked about this issue a lot. When I started here I asked the same question as you, and got the answer that you should read the old discussions about the issue. You will find answers about the speedo-problem, so start with the "Search" -option. I did it the easy way and changed my Ford T10 to a Chevy T5 -gearbox Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 1, 2002 Share Posted November 1, 2002 I had a simular problem. I changed the speedo teeth to match closest to the original Z speedometer and had a cable made. For specs on the teeth sizes you need goto this page http://www.geocities.com/zgarage2001/engine.html I hope this helps Quote Link to comment Share on other sites More sharing options...
