KoolMan Posted July 16, 2012 Share Posted July 16, 2012 (edited) Hello, I have done the E12-80 Distributor upgrade withe the MSD Blaster 2 my z has been running great after the upgrade. Since the upgrade I have been running my z without the tach it hasn't worked since I did the upgrade. Anyway I'm trying to figure out how the wiring goes. I have been reading up on it but I think my problem is that I don't remember which wires are the ones that go to the resistor(removed after upgrade) I uploaded a picture of my setup. I have a Connected the E12-80 to the coil and found the current wire and connected it since I did not have the tach I did not do anything else with the rest of the wires. I have four wires 3 are not connected right now. A) Was connected to the coil with the points distributor. Green/White and the other is black with yellow tip thicker cable B ) Was connected to the resistor. the cable one is black/yellow and the other is black. C) Added for the E12-80 distributor The only way that I can get the Z to start is to connect the (pic B ) black wire to the coil all others don't work. I have a four cable tach on my z and just got a 280z tach that ill be putting in. But I still have a question about this. On the tach I moved everything to the other 240z housing but I still dont understand what I'm suppose to do with the white/loop cable that has the black and read tape on each side. I know that the black wire moved from the top (240z tach) to the bottom (280z tach) Thanks. KM Edited July 16, 2012 by KoolMan Quote Link to comment Share on other sites More sharing options...
