front mount oil cooler
PR280z
I`m about to mount a RX7 oil cooler.Would like to know which is the feed hose and which is the return hose from the oil filter adapter? Is the feed hose on the lift or from the right of the adapter? Also does the feed line connect to the top thread of the oil cooler or it does`nt matter?
Uploaded with ImageShack.us
Edited by PR280z
Oil coming from the engine is supposed to enter the top port, and return via the side port.
Check THIS diagram for an illustrated flow path if it helps. It may work either way, but this could cause issues with the thermostat, so I would just plumb it properly from the beginning.
Lance, Thanks for the resurrection of the RX7 OIL COOLER topic(2009). I don`t think i would have found it! Once again THANKS!!! I owe you one! When your ever in Puerto Rico let me know...we`ll take the ZETTO- BASTARD for some BOOSTING-FUN!!! ;)
