Solid Lifter conversion issues.
Xnke
This issue WAS solved...car ran beautifully with a new cap and rotor (A second new cap and rotor, mind you!)
And then it threw a lash pad at about 3500RPM, on a downshift.
And THEN I realized why it threw the lashpad, when I removed the rocker arm with my fingers, WITHOUT adjusting the solid lash adjuster.
Even though the valve stems were (I thought) adequately lubed up with Permatex Ultra-slick mixed 50/50 with engine oil, even though the new valve guide seals were on correctly, I have managed to stick the #6 valve about half-lift. I will assume that it's now bent. I am not at all pleased with myself.
Head will get removed when I'm not sick of looking at it again, and we'll give it another shot.
Easy. It wasn't stuck when I put the head back on. It got stuck after I installed new valves, lapped them in, reinstalled the head, got the car running again, and drove it about a mile. As if the new valve stem seals sealed a little too good on that valve, and it seized in the guide.
Unfortunately, it's half-open, and the car continued to run till I got off the main road and stopped. I am worried about the condition of the internals; and don't particularly care to find out this evening.
