My IACV solution
adam78280z
I was going to run this as a firewall mounted setup but just didn't have that fuzzy feeling about it for some reason (although I know it would work). This is a stock l28et Manifold that I've shaved etc. I tig'd a 1/4" aluminum plate to the manifold and then drilled/tapped the plate to mount the xj4.0 IACV. I though about putting it on the bottom but need the room for my wastegate/turbo junk.
