bigbore468 Posted August 31, 2012 Share Posted August 31, 2012 Am looking for some information on Holley carb needle & seats; hopefully grumpyvette or any other carb tech guru can shed some light on this subject. The specific application for the needle & seats are for Holley 4150 DP carbs with center hung bowls running pump gas with 10-15% alcohol, not e85. Also .097" seats, non adjustable captured viton tip needle; like Holley P/N 6-506 I've noticed there are two different size diameter needle stems that Holley uses. See the pictures for reference. My questions: Are these supposed to be interchangable? I've recently purchased a few genuine Holley 6-506 needle & seats and they have the fatter stem. NOS same part number needle & seats I have from years ago have the smaller diameter stem. Is there any advantage to using one or the other with a particular float; either duracon or nitrophyl? I know the alcohol in the pump gas will tend to swell the viton tip a bit, and could cause sealing issues; which is exactly the problem I'm trying to solve. So assuming the fuel system is clean, float levels set properly, proper steady fuel pressure, etc., is there a needle & seat / float combination you would recommend? Appreciate your advice. Quote Link to comment Share on other sites More sharing options...
