timsz Posted September 1, 2012 Share Posted September 1, 2012 Can you powder coat engine mounts or other mounts (insulators)? The parts with the rubber. Thanks, TimsZ Quote Link to comment Share on other sites More sharing options...
cockerstar Posted September 1, 2012 Share Posted September 1, 2012 (edited) The engine mount arms can be powder coated without issues. The isolators with the rubber cannot. The part must reach a minimum temp of 375*F for a minimum of 12-15 mins depending on powder chemistry to achieve a full cure. There are chemical means of curing powder that are less durable which would probably work just fine though. "Powder water" offered by columbia coatings out of TN is one option. I've also used MEK to cure it in the past as well with success. Edited September 1, 2012 by cockerstar Quote Link to comment Share on other sites More sharing options...
timsz Posted September 2, 2012 Author Share Posted September 2, 2012 Thanks alot. TimsZ Quote Link to comment Share on other sites More sharing options...
