Shifter for a 200 4R in a '73 240Z
Uncle Sherman
My '73 240Z has a 350 GM small block and a 200 4R trans installed. Currently the shifter is a ratchet thing that I don't like. I'd like to switch to a Lokar, who make a few different types - floor mount, trans mount or cable operated. Does anyone know which one would be the best or the easiest to install? If you use a Lokar, how long should the lever be? They make them in sizes from 6" to way too long.
Thanks for any advice.
Easiest in my opinion is B&M pro shift. It's not a rachet and has changeable gates for 4 speed. 280zcar has pictures of his mounted with 700r4 and I have one mounted with my current th350. I just fabbed up a mount plate, bolted shifter to plate, then plate where regular shifter collar went in tunnel.
