75 Z electrical problems
I have a 75 280z that is driving me crazey. It started with a melted fusable link. The tach also gave up the ghost. I replaced the alt. and reg. but it will still not charge. All fuses are OK. My question is can someone tell me what voltages should be present running and not running on the terminals of the voltage reg? --never mind I traced the wiring back to the ig. found a streached wire under the dash, intermittent power to the volt reg. -- problem solved --
Have a Blast - Go Fast
[This message has been edited by flazguy (edited October 26, 2000).]
[This message has been edited by flazguy (edited October 30, 2000).]
I had a similar problem where the guages would not work and it would not charge.
I traced it down to a small relay just above the fuse box. It used the case of the relay box for a ground and the small wire band from the case to the relay was coroded...
Myron
