Wrong caliper brackets?
I dont recall hearing if anyone has tried thay though they may work. The calipers on the s130 and the s13 are very similar in design. Also, the rotors are nearly identical on both cars. What may be different between them which might make it harder for you is the caliper hanger/bracket. If these arent the same it may not be possible to mount the caliper. Used s13 rear brakes arent too hard to find, give them a try and post here what you find. Id be very interested in seeing the differences.
