Thermostat Housing Bolts
the bolts that hold My thermostat housing to the head have snapped. (77 280z with L28). I know that i can slide the housing off then slowly remove the bolts but i was wondering if there was any way that i could use the same length bolts that are fully threaded in place of the snapped ones? Also what are the lenghts so i will know how short to cut them? Any comments are appreciated greatly :confused:
No worries about bolts that fully threaded. They do the same thing.
As for length, you could just measure the thickness of the thermostat housing with a ruler at the two bolt holes, and add 5/8 inch for thread length into the block. That's 2 bolt diameters additional length (8mm x 2 = 16mm =~ 5/8 inch.) which is about what you need for good grip in the head.
The bolts are 8mm x 1.25 thread pitch if your wondering that too.
Happy bolt shopping!
Thanks! helped a ton
Sounds like your all set, but I switched to studs on the housing. Easier on the aluminum threads, and easier to line up during installation.
by studs do you mean a long threaded peice and a nut that id removed from it insead of removing the entire peice? Just want to be 100% sure before i do this
