rags Posted January 8, 2001 Share Posted January 8, 2001 Just picked up a TEC II for my turbo 240 and hava a few questions for the experts. The first is where to mount the sucker in a 71 when the battery is in the stock location? Who has any maps that work with a stock L28t without an IAC? Will the Nissan knock sensor, water temp sensor, throttle position sensor, and O2 sensor work? Any help is appreciated. Joe Quote Link to comment Share on other sites More sharing options...
TimZ Posted January 8, 2001 Share Posted January 8, 2001 quote: Originally posted by Rags: Just picked up a TEC II for my turbo 240 and hava a few questions for the experts. The first is where to mount the sucker in a 71 when the battery is in the stock location? Who has any maps that work with a stock L28t without an IAC? Will the Nissan knock sensor, water temp sensor, throttle position sensor, and O2 sensor work? Any help is appreciated. Joe I've seen them mounted either on the firewall, or on the front left of the engine bay, on the wheelwell (engine bay side, of course) in front of the strut tower. I would not recommend trying to use somebody else's maps, as they are pretty sensitive as to cam profiles, injector sizes, etc. You'll probably spend more time trying to 'straighten out' somebody else's map than you would in starting from scratch. As far as sensors, The water temp sensor should work. Not sure about the TPS - is it a variable resistance type, or just WOT and closed throttle switches? Not sure about the knock sensor - do you know it's characteristics? The O2 sensor will work, however if it's not a 3- or 4-wire type, I'd replace it with one. Sorry I can't tell you more, but I didn't start with the L28t electronics, so when I installed my TEC, I went with the recommended GM sensors. If you have specific tuning questions, I'd be more than happy to help... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted January 10, 2001 Share Posted January 10, 2001 Rags, did you get the Windows software with that puppy? Quote Link to comment Share on other sites More sharing options...
rags Posted January 10, 2001 Author Share Posted January 10, 2001 I have Pafz2g software. Quote Link to comment Share on other sites More sharing options...
Moridin Posted January 18, 2001 Share Posted January 18, 2001 How is the TEC II working. Do any of you know what kind of power gains you got from it? Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted January 18, 2001 Share Posted January 18, 2001 quote: Originally posted by moridin2004: How is the TEC II working. Do any of you know what kind of power gains you got from it? Quote Link to comment Share on other sites More sharing options...
rags Posted January 18, 2001 Author Share Posted January 18, 2001 I'm still picking up parts, it hasn't run yet! Quote Link to comment Share on other sites More sharing options...
