280z LS1 conversion question
I purchased this 78 Z last year and it's time for her to join her sister , 83 280ZX with LS1 and 6 spd trans. I recently purchased a wrecked 02 Z28 with an auto . Question for those with auto conversions , how much room do i need to make to the trans. tunnel to clear the trans. and where if any ? Thanks .
I recommend you go thru all the build threads and find somebody with your tranny and send them a private message. I asked same question a while back and never got an answer. Once folks finish their project they aren't on the forum as much. Also, most of us start with a 6-spd then change to automatic after breaking a bunch of axle parts. The guys I know have retrofitted to Turbo350s. If I ever retrofit it will be to a Powerglide because that is what the local hyperf tyranny shop specializes in. When I did my swap with a T56 I pre-hammered my tunnel by other folks recommendations. Turned out I didn't need to hammer at all. If I were you I'd bolt in the JCI mounts and hammer as needed rather than worrying about what others did.
